Wireless routers- pls help
14 Aug 2003
cyberspace
Hi,
Thinking about buying a wireless router. I'm going to use this router
TP-Link TD-W8960N 300MBPS Wireless N ADSL2+ Modem Router for BT connections as I have a BT connection.
How easy is this router to set up?
Once set up-how secure is this router?
pls help
easy and secure enough to set up but the 8961N (pretty much the same) I have has some issues with reconnecting to the isp if it drops out (my other router is fine)...
It may just be the one I have but it's worth considering
