Hi
Just about to install my router (Linksys WAG54GX2). It will be "wired" to my main PC but wireless for the wife's laptop.
Here are a list of the main security issues that I have found to put in place.
Have I covered everything? Please let me know if there are any other issues?
Thanks S......
1) Don't use TCP/IP for File and Printer sharing!
2) Follow secure file-sharing practices
Share only what you need to share (think Folders, not entire hard drives)
Password protect anything that is shared with a strong password.
3) Turn on (Compatible) WPA / WEP Encryption
6) Secure your wireless router / Access Point (AP)
7) Disallow router/ AP administration via wireless
8) Use MAC address based Access and Association control
9) Don't send the ESSID
10) Don't accept "ANY" ESSID
11) Use VPN
12) Change the Default Administrator Password:
I also found the following:
1.Assign Static IP Addresses to Devices
Most home networkers grativate toward using dynamic IP addresses. DHCP technology is indeed quick and easy to set up. Unfortunately, this convenience also works to the advantage of network attackers, who can easily obtain valid IP addresses from a network's DHCP pool. Turn off DHCP on the router or access point, set a fixed IP address range, then set each connected device to match. Use a private IP range (like 10.0.0.x) to prevent computers from being directly reached from the Internet.
Thanks S......
11) Use VPN
