Wireless setup not showing correct speed
1 May 2003
I have a new Wireless setup at home just installed tonight. It is all working fine and I can connect to the Internet and all that.
But my connection speed on my PCI card is only showing as 58mbps. My equipment is as follows
Netgear Rangemax - WPN311 270mbps pci card
Netgear DG834N 300Mbps Rangemax NEXT Wireless ADSL2+ Modem/Router/Switch/Firewall
The Modem is downstairs and the PC is one floor, that is directly above the Router modem. Even with the floor boards in the way and some pipes the connection speed should be better. I am getting full signal connection. What am I doing wrong :confused:
Thanks in advance :)
