wireless setup - pc/pda/psp
3 Jun 2006
hi all... ok.. I'm new to wireless... i have my pc which currently not on a wireless setup. I also have a sony psp and a PDA with wireless capabilities.. i am just after finding a decent setup complete, so i can can use my PDA and PSP online.. hope someone can point me in the right direction..
thanks a lot...
Freakish_05 said:
Read the FAQ at all?
The FAQ said:
OcUK are happy to provide the resources of these forums to responsible individuals without charge. They cost a substantial amount of money to maintain and use considerable amounts of bandwith which is paid for exclusively by OcUK. As you know OcUK are in the computer hardware business and therefore the promotion of OcUK's competitors is forbidden. Examples of promotion are :-
* Posting links to competitors websites
* Posting links to reviews that promote competitors
* Quoting the names or contact details of competitors
* Offering to provide the names or contact details of competitors
* Using the forums to notify a member of intent or actual supply of names or contact details of competitors
* Listing competitors names, URL's or e-mail addresses in signatures
* Listing competitors names, URL's or e-mail addresses in profile
* Posting links to or the mentioning of auction sites
* Disguising attempts to do any of the above
If you have dial up and have a spare ethernet port on your pc, you could just enable ICS (have a Google if you're not sure what it is) and plug a WAP into the ethernet port, such as this one:
http://www.overclockers.co.uk/acatalog/Access_Points.html#aNW_2d012_2dNG
If you have cable and an ethernet modem then you could get a wireless cable router such as the WRT54G, plug your pc into this via ethernet and connect the pda and psp wirelessly:
http://www.overclockers.co.uk/acatalog/Cable_Routers.html#aNW_2d000_2dLS
Finally, if you have ADSL then you could get a wireless ADSL router such as the DG834G, plug your pc into this via ethernet and connect the pda and psp wirelessly:
http://www.overclockers.co.uk/acatalog/Broadband_Routers.html#aNW_2d017_2dNG
HTH, null :)
Either get a WAP like I said perhaps consider an ADSL router? Means you won't need the main pc on all the time, uses less power, more secure, less work for your main pc, more future proof (spare switch ports for new devices etc.). Depends what your budget is but I'd go with an ADSL router.
HTH, null :)
