wireless setup
28 Jul 2004
Solihull, Birmingham
I'm looking to get an Acer Aspire 5633WLMi in the next few days, and to make use of its (copied from spec) Network: 802.11b/g Wireless I want to set up a wireless network that will allow me to do the following;
connect my main pc to the network either via wired connection, or (as I've got no wi-fi card installed) usb adapter, and also to connect my Nintendo Wii to the network.
I've been looking at a Belkin Wireless Modem Router USB Adapter Bundle 802.11g, some websites mention its an ADSL router, some Cable...which is right?
Am I right in thinking that this 802.11g standard will let the router and laptop connect and seeing as its a usb bundle, then the usb adapter will be ok connected to my pc, allowing that to connect to the network also?
It's a cable router you're after then - Belkin (not that I'd recommend them, 99% of their routers are garbage) do bundles with both ADSL and cable routers.
The USB adapter should work fine in your PC, provided there are drivers for it.
