I used one of these to route my btvision beofre I got homeplugs, also there is a version that is a printserver wgps606 which is also good if U wanna relocate your printer. These should extend your wireless signal to the uppper floor & boost your signal strengh. I'm outside using an access point at the mo as *** builders are in.
it should be as mine is connected to an o2 box at the mo but belkin do wireless access points aswell so its up to you really. or buy homeplugs at higher cost.
