My flatmate got himself a PC with wireless adaptor, but he cannot connect in his room to our wifi from Virgin Media. The router is in the lounge, about 3m away from his PC, but obviously walls weaken the signal and there is a water tank in the way from router to his PC (so it might the cause). So he had to put his PC on a night stand and rotate it in a certain way and only then he got himself 2 bars out of 5.
I was wondering if it is because of weak signal from VM Super Hub router or because of interference? And how would you recommend me to fix the problem (apart from obviously using a cable)? I was thinking of either buying new, more powerful router (but I don't know how good or bad is VM Super Hub) and if that will help just get rid of VM router. Or otherwise connect VM router to new router and put it in my room. Or otherwise use something like signal repeater or booster (but I do not know how good they actually are).
