Wireless switch / receiver for lights
4 Dec 2002
Bourne, Lincs
Currently have some under cupboard lighting that runs on the Ikea Tradfri drivers which we use Philips Hue to control via Alexa.
With a move, will be taking the smart part away, however I want to put a wireless switch inline between the plug and the tradfri driver, does anyone have any recommendations for receiver I can put on the cable, then have a wireless switch, after ones that do not need to be wired in or need a battery.
Thanks
Have a look at the Quinetic wireless switches and receivers. The switches are completely wireless and are self powered (kinetic). Regarding the receiver you could put one inline but it would need to housed in a junction box, or they also do socket adapters so you could plug directly into them
