Wireless USB Adapter for Windows 7 64-bit?
29 May 2007
Dublin
My Zyxel USB adapter does not work in Windows 7 and Zyxel have no 64-bit drivers. Someone here said Netgear and Linksys were good but on the Netgear site they do not have any 64-bit drivers for Windows 7.
I'm also looking at the Linksys WUSB54 - but it only has drivers for XP on its site. Does anyone know if it will work in 64-bit Windows 7?
Or any Wireless USB adapter that works in 64-bit Windows 7? Or do I have to go back to 32-bit to get internet access :confused:
I have a cheap Edimax 7717 which I bought because it was the cheapest Draft-n device I could find. Works perfectly with the Windows drivers.
I'm running Windows 7 64 bit and bought a Linksys WUSB54GC, (bought it for £20 from a purple shirt store) it has vista 64 bit drivers supplied on the disc which work fine with Windows 7. Don't run the install from the disk, just plug it in, go into device manager, select it, select update drivers and point it to the cd, works a treat. Hope this helps.
Link: http://www.linksysbycisco.com/UK/en/products/WUSB54GC?lid=LearnMore_WUSB54GC
OK I'll try that one. Cheers.
