1. At the most basic, it’s a damn good receiver, excellent picture and audio quality.
2. If you have official subscription cards/cam, they’ll work in it.
3. If you have unofficial subscription cards/cam, they’ll probably work in it too!.
4. It has inbuilt games, and lots of ‘em.
5. You have a choice of “skins” so you can change the appearance to suit your taste.
6. It has capacity for unlimited no. of channels.
7. It has a massive support network on the web, tons of programs / addons etc.
8. It has DiSEqC / Usals / UHF loop (not 500 series) / Digital Audio out …
9. It is a PVR, add your own HDD and off you go (not 500 series).
10. It has USB port / CF reader to add more flash memory to store more games / addons etc (not 500 series)
11. The remote control will also control your tv (not 500 series)
12. It has LCD screen to show channel / volume / time etc. (not 500 series)
13. Most importantly, it has Ethernet port!
From your Dreambox…
14. You can connect to internet via pc / router to download addons / skins / games and lots more
15. You can set up a cardshare, for example to watch encrypted channels on Dreambox in bedroom using card on box in sitting room
16. You can watch a DVD that being played in PC's DVD drive
17. You can connect to your PC and record to PC’s HDD if you haven’t a drive in the Dreambox
18. You can view photos and play music and video files stored on PC
From your PC, and from a remote PC via Web…
19. You can send / receive files from Dreambox
20. You can easily update software “image” in Dreambox
21. You can connect to Dreambox web interface through Internet Explorer / Firefox and have full control over it, change channels etc.
22. You can watch live TV stream, excellent picture quality on home PC, difficult to set up on remote PC
23. You can view EPG on PC, and set timer to record
24. You can type a message and send it to TV screen from anywhere on the Web
