- 22 Aug 2003
- Bucks
My router is Netgear DG834G which can (allegedly) handle both wired & wireless connections. My pc is connected to this router via the 'wired' route & I'm fine with that.
I want to add a 2nd desktop pc to this router and although I have all the cat6 cables & faceplates, network card etc to physically plumb it in, I am beginning to think it might be a whole lot easier to just grab a wireless network PCI card and connect this pc wirelessly. It's my missus' house not mine & she's not all that keen on me drilling through walls etc
1. Can anyone recommend a decent PCI wireless card (budget £30 max). I saw some Belkin ones down at my local shop for about £25 which fall within my budget. Are there any cards to steer clear of?
2. Are there any extra security measures I need to take with a wireless connection? This pc will be running AVG & ZoneAlarm -is this enough or are there some additional router settings I should be aware of?
