wireless wifi adapter for macbook
Every MacBook, MacBook Air and MacBook Pro has come with WiFi built in. What are you trying to do?
in general, now I am distributing the Internet to a MacBook from a teephone and the speed is very low. I heard about some kind of wireless routers but for Windows, which do wi-fi. like those on the link. Or do I not correctly understand their meaning and principle of operation?
Why are you using your phone for internet? (I'm guessing you mean you're just using your phone as a hotspot at the moment) Do you not have internet in your house? Or is this for using on the move.
Unless your home internet is using ancient equipment, it'll have wireless built in which you can just connect to. If not, then you'll need a wireless router. But we'll probably need a little more info to work out what you need.
The USB dongle you've linked to just receives wireless which, as mentioned above, Macs come with anyway so they seem a bit redundant.
Also, you might want to edit out that link. They're considered a competitor in that regard which is against the rules ;)
oh I understood you !! it won't change the situation. Yes, I do not use wired Internet, but the phone as an access point because I live in an inconvenient place where it is not profitable to have a full-fledged Internet now. dual, this thing will be an access point instead of a phone - but as chonyala - no.
and for the link thank you - I will delete
I'm a good user, I don't want to break the rules)
