Hi there everyone
I have a Dell Latitude D620 laptop with some very annoying wireless problems...
For example I have tried with two networks - One at my flat and one back home, both showing similar problems so i've identified its not a problem relating to network/router configuration.
With both of these networks i can connect to them and receive an IP no problem. but my internet browsing and msn will behave irraticly ie pages sometimes wont load, i sometimes wont receive messages, i can only sometimes connect to my VPN client etc.
If i try and ping my gateway ie router I notice I will receive packet loss. If i use my wired adaptor then its fine.
Pinging my router for example will sometimes result in times of 3ms-700ms with packet loss in the reigon of 15%-70%
I've gone through the usual routine of updating drivers and re-installing the card but with no luck. My wireless network card is a Intel(R) PRO/Wireless 3945ABG.
If anyone has any ideas i would appreciate it
Thanks
David
Thanks
David
