Permabanned
- 18 Feb 2008
is ethernet faster than wireless ?
do you lose any speed or disconnects ?
what about a wireless network usb stick are tthese good
Depends on what stick you get. Internal cards are better due to having better aerials and less heat being trapped inside an enclosure as they get warm.
Some USB sticks such as some from linksys have high gain aerials so can handle distances well but for the cost you'd be better off with an internal card.
