Wirelss problem... Help needed!
1 Jul 2004
Sunny Manchester
Hi there,
We have Wifi setup in our house. Perfect for mine and my dads laptops. Now, my mum has just got a new pc off a family member. Tried to connect it directly to the router like the last pc but no joy. Cant get the driver to work for the ethernet socket on the mobo.
Anyway, we've got a wireless network adapter here which should allow the pc to be wireless.
Now it does'nt come with any software etc. So I searched on Linksys website. Found the right model, (Linksys Wireless B USB Network Adapter).
Ive downloaded the driver and manual. In the manual it says that it should be plug and play. Plug it in and windows picks it up and should install it, well it does'nt.
So I go to install the driver. Click on the driver setup and it does'nt run or anything. All I can do is open the wireless utility from Linksys but that wont run as the driver is'nt installed.
How the hell can I get this wireless adapter to work? Its really starting to annoy me now...
Thanks, Help much appreciated...
Ben
It found it the first time I plugged it in. Did'nt find any drivers for it.
After that, everytime I plug it in, windows does'nt even recongise it.
Win XP Pro.
Cant get to the machine right now to disable firewall etc, will try that tomorrow.
Thanks.
