OK so I bought a nest 3rd gen learning thermostat from here, and I am sure it works, no reason to doubt it. I have just moved into a new flat but the control mechanism thingy for the boiler is knackered, hence the purchase of the Nest. Boiler works completely fine in manual mode, just the remote module is goosed.
I am waiting on getting a mate who is a heating engineer to come round and fit it, but it's taking ages given he is doing it as a favour, its winter, its Scotland, its p***ing down from the heavens, etc, etc. so I thought surely I can wire it up myself given the boiler already has a wirelress thermostat albeit the module itself is knackered. Surely its just a case of copying the wiring?
So I disconnected the current heatlink which looked like this when wired up
https://i.imgur.com/6qoGzZW.jpg
So it's reasonably simple right, live and neutral and two identical black wires into the call for heat and the other for yeah I dunno
. So i tried wiring this up to the nest in the same pattern, it powers on but hte yellow light (disconnected) stays on. I tried reversing the two black wires in case I got them the wrong way round but it's the same. THe heating works fine in manual mode with the nest connected.
https://i.imgur.com/lT6HK80.jpg
So does anyone know what I am doing wrong? I know I can wait for my mate to come do it but it's doing my head in a bit and it's not like I need to actually wire anything into the boiler itself so I can't see it being that unsafe surely? I have some examples online where a cable is wired from 2 on the nest directly back into the live terminal, however given that was different to what my original wiring was I didnt want to risk that, I am not crazy after all just impatient
Anyone have any insight?
Cheers
Cheers
