Suspended
- 18 Sep 2014
- Planet Earth
I currently have a master socket downstairs with an Openreach BT VDSL filtered faceplate. From the MS a cable has been run (some years ago now) to an extension slave socket in another part of the house and from that socket another cable run to a further slave in yet another room (all done professionally).
What I want to do is remove the wires for that first slave socket from the MS - pins 2 & 5 and connect them to the two empty pins on the front of the VDSL faceplate. They should then be filtered, removing the need to use VDSL micro filters and I should be able to use a telephone to RJ11 cable straight from the slave into the HomeHub?
Now the question - does it matter which way round the wires from 2 & 5 are connected to the two pins on the MS faceplate? My instinct is that the polarity isn't important but would like that confirming?
I assume that once I go down this road both slaves will then become filtered and only of use for Internet i.e. no longer able to be used for phones?
Thanks for any assistance in advance.
