Wiring help - Molex
22 May 2010
Minibotpc
Just need a quick confirmation here
According to this, if i was to wire it to a Molex plug from my PSU. I would wire the red wire from my molex cable to the DC 6v - 30v and then a ground wire from the molex cable to the ground on the furthest left point connector.
Is it as simple as that?
What are you trying to achieve?
Personally I would think the yellow 12v molex would go to the 4th pin (the +) and the black ground molex pin would go to the 3rd pin (the - pin)
Just trying to wire this up to a molex connector so i can connect it to my psu to power it. I wanna measure water temp in my loop.
