My wiring loom fell out of its clip and dropped onto the engine, resulting in 10 charred wires, 2 bare wires and some electrical gremlins.
My plan was to cut out the damaged sections and solder some new wire in. But I read somewhere that the vibrations will break the solder connections, will it be ok or should I use something else?
Any ideas where to get the wire? Also is there any particular type of wire I should be going for as it is in quite a high temperature area.
Thanks
Thanks
