Wiring multiple PWM fans in parallel
11 Jun 2003
Hampshire
Quick sanity check. I’m wiring three fans to a single header on my fan controller. The amperage is fine.
Should I disconnect the tach signal from two of the fans, so only one is reporting speed. Leaving the 0v, 12v and pwm in tact.
Or am I missing something?
Correct, multiple rpm input signals would likely cause some serious mess for speed reading.
Thanks for replying chap. I’ve already wired it up mind you. Everything’s looking and working great.
Thanks again.
