So I fitted my Gerbing heated gloves socket today. Unfortunately space was tight where the wiring runs through the frame so I had to cut the wires at the fuse holder (my plan was to feed the wires through and just solder it back on)
Problem is that both wires are black which I discovered after I'd ran the wires back to the battery and I don't know which is supposed to be positive and which is negative. Is there any easy way to test it?
This is the Gerbing socket.
