wirless card for win 7 64bit
21 Feb 2010
hi all
could anyone shed some advice on what to get for wirless internet, just built a new system and my old wirless card wont be supported for windows 7 (only supported up to win xp 32bit)
so need a new one, prefer something to go in a pci slot but not really that fussed aslong as its hassle free
thanks in advance
steve.
Hi there,
Have you tried the card in your new windows 7 system? I had a Belkin USB wireless adapter that failed to work on vista (no vista drivers) but when I put it in my new windows 7 system it worked right away.
If it doesn't work, I suggest looking at this - a nicely featured card at a good price, and I have used many edimax wireless cards and they have all been excellent.
Out of interest, those who are using the Edimax on Windows 7 64bit, where did you get the drivers? Edimax's site? Windows update?
There may well be some on the disk or the web - but I have no clue.
I simply plugged it in when I turned on my PC for the first time, it was recognised by windows before the Windows install was even finalised and I was able to go online as soon as it booted up.
I believe I later updated the drivers via Windows update, it was all rather painless.
