Witch gts have warranty still on when you remove stock cooler ?
12 Jun 2007
Ireland
Short and simple the same as in title : Witch gts have warranty still on when you remove stock cooler ? is it evga ? :confused:
I've RMA'd non-EVGA cards i've removed the cooler from before.
You aren't buying an EVGA just for this reason, are you?
well yes only for that reason you have any better ideas what should i buy ?
give them fast as stock is not going to last forever :eek:
I broke a card replacing the cooler, I stuck the default one back on and sent it back for a replacement.
They won't tell unless you break the original somehow, get the cheapest GTS and don't worry about it.
oh kk ty ;)
ps: i think i fixed mine 2900 well fps does not go down removed it inserted installed new direct x novermber edition reformatted hardrive installed new drivers if it will work fine i stick with 2900 but if it goes wacko again im getting gts
