Witcher gremlins
22 Nov 2004
NW5
Got given this yesterday, as a late present, so went ahead and installed it. :) Downloaded and installed patch 1.4 and language pack no probs.
Went to play it, and after the intro witcher stops responding and closes :(
Had no problem with the demo at all - only difference was I had a different monitor @1024 native. Now got 22" widescreen @1280.
Running Vista 32bit, GTX 280, 2Gb ram.
Search only revealled people not seeing intro, or random crashes further into gameplay. Any ideas?
Did uninstall the demo ages ago, and ran a reg cleaner (do after every un/install).
Was trying to stay away from the witcher forums, as something about the colour/layout bugs me, but have registered so may give it a go. Find these forums easier on the eye.
uninstall, then reinstall the basic game and see if that works.
If it does, update to 1.4 and try again, then do the same with the langauge pack.
That will eliminate those as problems.
Try setting it to 800x600 to start and all graphics on basic.
It's been solid as a rock for me since I upgraded to the enhanced edition. I dunno, try upgrading sound and graphics drivers, or turning off EAX?
Did this, and left everything as default, and it works :) Only difference was I originally installed to C:\Games, where as this time it went into Program Files...odd.
Seems stable as had a 2hr run last night with no issues, with everything on high. Graphically very pleasing - was suprised I could go to bed with someone (that wasn't in the demo;))
