Hello!
I'll give my old PC to my sister after I build the new one. I'd like to refurbish it's cooling a little bit, but I'm confused about what to do with the CPU heatsink. The case is an old Thermaltake Soprano, with only 1-1 front/back 120mm and 1 side panel 92mm. I've already changed the original fans to Arctic Cooling fans (F12 PWM front intake, F12 Pro PWM back exhaust, F9 PWM side panel intake).
There is 195mm clearance from motherboard tray (185mm from mobo), but the side fan is perfectly over the CPU. What would be the better solution:
- Leave the 92mm side fan where it is, and buy a smaller heatsink (Thermalright True Spirit 120M / Thermalright Macho 120), or
- Remove the side fan, and buy a taller heatsink? (Alpenföhn Matterhorn / CM 212 EVO)
Thans in advance for your help!
