With the pound be so strong...
15 Aug 2003
Essex
..any one tempted to import a 360 Elite?
I am :o that way i have a UK + US box aswell so can get some NTSC games in.
Any downfalls to this?
Tried&Tested said:
But, do you want want them bad enough to spend all that money on another xbox..that's black? :)
I already have 2 xbox360's aswell (though one was £10) - but pretty much...yea
Tried&Tested said:
Overkill dude.
But your money! Go get one.
the £10 is used as a media extender in my front room mind.
I dunno, i wouldnt mind a NTSC box but i might grab a core instead - i just wanna buy why its cheap :D
Might not be as risky with the Elite, it's revised ain't it? Lower temps and that.
Probably not gonna be as prone to breaking at least, so might be worthy.
Always a risk though.
thedoc46 said:
Do you live on a by-pass?
You do know they've started using much quiter BenQ drives in some 360's now?
Oh, and stop being a ****.
Soulja said:
No it's not revised, same noise level and same temp sadly :(
Not entirely true:
The upcoming Xbox 360 Elite to reveals component reduction and new signal processors
There were rumors the new SKU would swap IBM’s 90nm Xenon PowerPC processor in favor of a cooler running 65nm variant. Microsoft made no mention of such swap with the official announcement of the Xbox 360 Elite. Popping off the heatsink reveals a different CPU revision. It is unknown if the different revision correlates to a 65nm Xenon, however, other changes to the PCB raises further speculation.
Microsoft has revised power delivery on the new Elite. The Xbox 360 Elite makes use of smaller capacitors arranged in slightly different arrangements. Microsoft has also reduced the amount of MOSFETs installed in the power supply section of the PCB. There are also fewer resistors located above the CPU as well.
However, despite the power changes, the die size remains the same as with the HDMI-less Xbox 360. One could speculate the Xenon CPU is still 90nm but Microsoft has opted to integrate a different thermal bin, similar to how AMD bins its regular Athlon 64 X2 and Energy Efficient models.
Xbox 360 owners have had issues with the red ring of death, including DailyTech staff, which is possibly due to the BGA packaging of the CPU and GPU. When things get too hot, the connection between the BGA part and the PCB can disconnect when the PCB warps. Microsoft has attempted to address this problem by surrounding the CPU and GPU with epoxy on the Xbox 360 Elite. It is unknown if newer revision Xbox 360 Core and Premium bundles feature the same preemptive measures.
source
So although the cpu is probably still 90nm, it looks like they are trying to address the heat/reliability issues.
