System:
Windows XP
Gigabyte DS3
C2D 1.86Ghz
Just bought a WLAN PCI card using the Realtek RTL8185L Chipset. I didn't get a 'quick-installation guide' in the box as promised so have tried two methods so far:
1. Put the card in the motherboard straight away, which causes the computer to fail to reach BIOS.
2. Installed drivers and program from Realtek website before installing card. However, I put card in and the same problem occurs.
When I un-installed the drivers to start anew, the computer then started to bugger up after a restart. Thankfully I've got rid of those problems with a few reboots, but I'm a bit wary about going any further without some proper advice. I've tried contacting Realtek but they're taking ages, so if anyone here can help I'd really appreciate it.
Thanks in advance!
Windows XP
Gigabyte DS3
C2D 1.86Ghz
Thanks in advance!
