22 Nov 2006 at 00:21 #1 nemtizz nemtizz Soldato Joined 16 May 2006 Posts 14,658 Is anyone elses WLM just not working? Mines taking ages to react when im typing in my password, plus its just failing to log in.
22 Nov 2006 at 17:46 #2 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,658 Tried reinstalling and clicking help, but both did nothing. Any ideas? Last edited: 22 Nov 2006
27 Nov 2006 at 00:10 #4 Tony Williams Tony Williams Soldato Joined 13 Jul 2006 Posts 3,371 Location Hell!! \m/ Try the troubleshooter. TOOLS > OPTIONS > CONNECTION > START and post your findings.
27 Nov 2006 at 00:17 #5 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,658 All fine. Also when i click sign in it dosent even try to log in, it just immediately appears with that error message.
27 Nov 2006 at 00:23 #6 Tony Williams Tony Williams Soldato Joined 13 Jul 2006 Posts 3,371 Location Hell!! \m/ Does IE work? Try logging in with a different account.
27 Nov 2006 at 00:29 #7 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,658 Ive tried logging in on multiple accounts, but the problem still persists.
27 Nov 2006 at 06:30 #8 mattbrown91 mattbrown91 Associate Joined 27 Sep 2004 Posts 2,328 Location Ilkley / London I had this a week or so back. Same problems, I could get 4.7 to log in. What I did was, uninstall, revert back to an older version 7.x or 6.x then reinstall the latest version.
27 Nov 2006 at 17:09 #9 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,658 Thanks for the tip, but it didn't work.
27 Nov 2006 at 19:06 #10 Tony Williams Tony Williams Soldato Joined 13 Jul 2006 Posts 3,371 Location Hell!! \m/ Did the old version login?
27 Nov 2006 at 19:15 #11 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,658 Nope not atall, it still took ages to react to the keystrokes and still errored. EDIT - I tried logging in on my brothers computer and it worked perfectly. Last edited: 27 Nov 2006
2 Dec 2006 at 16:02 #12 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,658 Well ive been emailing msn surrport for the last few days and weve finally fixed it, all i had to do was reinstall the MSXML3 library files.
