WLTM Motherboard for 4x DIMMs
26 Jan 2007
Leeds
Hi all,
Well my previously-faithful, 14-month-old Gigabyte P965-DS3 appears to be succumbing to age. When it was new, it had 2x1GB of memory, and threw my E4300 to 2.4GHz without any voltage increases. Then came 2 more DIMMs, 2 additional USB devices, and suddenly every voltage needed hiking up a couple of notches. Few months on and it won't boot with 4 DIMMs and OC unless all but 1 USB device is removed.
Time for a replacement, methinks. What I'm specifically looking for is something that can:
A) handle an FSB of 400 and up (planning on a wolfdale in 6 months or so, would like some OC headroom on it)
B) handle 4 sticks of DDR2 (Ballistix 5300) without issue
I'm not worried about SLI or RAID, and I have no PATA, serial, PS/2 or parallel devices, just 2x SATA drives and USB peripherals.
I'm currently thinking along the lines of a P5K-E WiFi, and would be grateful if anyone can confirm that this board would be fine with 4 DIMMs, as well as any other recommendations for things I haven't thought about :)
On a slightly different note, I'm planning on a Zalman CNPS9500A cooler, which is not going to blow down onto the motherboard components, but sideways/upwards (straight out of the case). Is that going to cause problems for the P5K-E, or is it going to be ok with the general case cooling (2x 120mm fans + PSU fan)? Wouldn't want to fry the voltage regs in the cause of better cooling for the CPU :S
Thanks for any advice!
Should have mentioned, don't really want to go above £110-120. Cheaper is better, unless it compromises stability :)
Cheers
don't run an Asus P5K but the abit IP35 series will so I guess that the P5K should too.
That's good to hear. Which Abit are you running, may I ask? I'd rather pick one that's been verified by an OCUK forumer than one that 'should' work :)
Nice - I think I remember a Tom's Hardware review of Vista with 8GB concluding that it was a very good thing indeed :)
Dont be taken in by that review. Did you actually read any qualitative information on what speeds increases were seen? Any graphs?
No, neither did I.
No, neither did I.
I guess that's a point... and it's true that 4 (3.2) GB under XP has so far not needed a swap file...
Back on track a little, anything else than the IP35 that's invariably happy with 4 DIMMs, or is that the flavour of the month? :)
Hi eddiew,
I'm with Buff on this one, Ive recently put together a new rig with an Abit IP35 Pro and 4x1gb Crucial Ballistix Tracers at PC2-8500. The ram and cpu are at stock voltages and only upped the MCH voltage one notch. Not a single problem so far :)
[edit: forget to mention the cpu is a quad Q6600 o/c'd to 3ghz on stock voltages]
Cheers D.M, good to know. I'd lament the lack of WiFi, but much rather a stable board and a PCI WiFi card than an unstable board with no PCI card :)
Pity it's so ugly :/
?you talking about the Abit IP35 Pro? The pics dont do it any justice, its much better looking in the flesh :)
It's the whole blue/black thing they've got going. With the copper heatpipe it looks kinda like a veiny bruise :(
That said, my case is windowless, what do I care once it's inside? :)
Is it better than the average PCI WiFi card? The one I have gets ~36 mbit, medium-low, while the laptop next to it gets 54 max strength...
Unfortunately it's a rented house and there's just no way to lay some Cat5 without wrecking the floor/walls :(
