WMP 11 problem?
18 Oct 2002
Brum
Hi everyone, could do with some help here if you dont mind.:)
For ages now i've had this problem where if I try to play certain video content off the net, say wmv files and the like, i get the below message:
Now i've searched around on the net and all I can find is that, like the message above says, is that I should re-install WMP 11 which I have tried numerous times. I've tried un-installing codec packs and re-installing different ones too, but no luck, just the same annoying message. I've also tried experimenting with different settings in WMP11, but it just wont work.
Please help if you can, as I wanna view that crash video in the Motoring thread!:D
Cheers.
