WMP 11 problems!
26 Jan 2005
Hey guys and gals,
Since beta 2 and beyond of the Windows Media Player 11, i have been unable to play MPEGS, it says there's an error and cant open them. I have no trouble opening them with Quicktime etc, i dont understand why it wont open them!? :confused:
Seeing as its a pretty major format to have a bug with!
Anyone who can shed any light on this or has experienced the problem themselves i'd love to hear from :)
Thanks :cool:
i tried one of the codecs "stinkys" mpeg2 codec. It didnt work.
To be more clear, here is the "web help" response that you get when the error message shows and you click the "web help" button.
You've encountered error message C00D11B1 while using Windows Media Player. The following information might help you troubleshoot the issue.
Cannot play the file
Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
Your sound device, such as a sound card or sound controller, requires an updated driver. To determine if an updated driver is available, see Windows Update at the Microsoft Web site, or see the sound device manufacturer's Web site.
Your sound device is not functioning properly. Try using Device Manager to check the status of your sound device.
To check the status of your sound device
Do one of the following:
If you are running Windows XP, click Start, right-click My Computer, and then click Manage.
If you are running Windows Vista, click Start, right-click Computer, and then click Manage.
In the pane on the left, click Device Manager.
In the pane on the right, expand Sound, video and game controllers, and then look for the name of your sound device.
If your sound device is listed but the icon includes a red "X," the device has been disabled. To enable the device, right-click the icon, and then click Enable.
If your sound device is not listed, in the pane on the right, expand Other devices. If Multimedia Audio Controller appears in the list, right-click the icon, and then click Update Driver or Update Driver Software. Follow the on-screen instructions to find and install the driver software.
If you are not able to find and install the correct driver software, see your computer manufacturer's or sound device manufacturer's Web site for further assistance.
You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again. For details, see your computer manufacturer's or sound device manufacturer's Web site.
You are trying to play a file on the Internet and the server might be temporarily unavailable or there might be a network issue. Try again later.
You are trying to play an MP3 file that contains compressed ID3 headers. The ID3 header is a portion of the file that stores the song's album information (for example, the song name, artist name, album name, and genre). This information is sometimes called a "tag."
To fix the problem, make a copy of the file and then use a non-Microsoft ID3 tag editing program to remove or reset the file's ID3 headers. After you remove the ID3 headers, Windows Media Player should be able to play the MP3 file.
Attempting to remove ID3 headers might damage the file and make it unplayable. Therefore, always make a copy of the file before you edit it.
If this solution does not resolve the problem, the file might be corrupted.
I too have an MPEG issue with WMP11 which I'm trying to solve - although I've not been able to spend too much time on it at the moment.
Mine I think is different to yours, however something which was definitely working in 10 but not in 11.
If I click on a .mpg link on a website there is a short delay, WMP11 opens up, another short delay and eventually the first frame of the MPEG file appears but it doesn't actually play.
The play bar indicates that it is playing and I can hit the Pause/Stop buttons (so it's not an autoplay issue) however the file doesn't actually play.
If however I download the MPEG file and then double-click it, WMP11 opens the file, short delay and then starts playing it.
It just appears to be an issue when I click on an MPEG file and in essence attempt to stream it things don't work.
Download it and watch it locally and all is well.
.wmv and .avi files are absolutely fine.
.mpg and other MPEG files were absolutely fine being "streamed" in WMP10.
Just seems bizarre to me, the first beta was ok but beta 2 onwards and this happens.
Im not sure about streaming but im guessing i'd have the same problem as you Stoofa.
It's infuriating, don't see any reasoning behind microsoft not releasing a fix or something. Im sure we're not the only ones with this problem. :confused:
