WMP-HC Capture Settings
15 May 2008
Hi Guys, I did a search for this and didn't find anything so apologies if this has been brought up before.
I am looking into the merits of using WMP-HC as my default media player and have come across what appears to be a limitation on image capturing from video.
Could anyone tell if it is possible and if so how, to do the following:
1) Change file format capture is saved as?
2) Change output size of captured image?
3) Change destination folder capture is saved to?
Thanks Guys.
Martyn
