wmp probs
22 Jan 2007
rhyl
i've ripped a couple of cd's onto my pc, when i try to play them all if does is randomise the tracks and the words "changing media" flash up in the bottom left corner.
it all works fine if i select one track at a time and play them individually.
this happens on both xp and vista. both are installed on seperate hhd's, but i can access files from xp when i'm running vista and vice versa.
can anyone help plz it drivin me crackers
Sounds like WMP is trying to switch between a CD track and an MP3. You could try rebuilding the WMP library on both systems. A quick Google should tell you the location of the library database file. Delete it and rebuild the library database, make sure that you don’t have any CDs in your drives.
