Is it possible to add media from a USB drive into the library in WMP11 at all?
I take a USB drive into work - and WMP11 will not allow me to add any media from the USB drive into the Library.
It starts up the Sync setup for the USB device, but it's not actually possible to play anything from the device.
The only way I can actually get it to play files is to manually open them from the directory.
Is there a way around this, it's really irritating!
Edit: I've found a way to do it now, you have to manually type the folder path in the monitoring folders option; it won't allow you to click on the drive itself.
