- 8 Jan 2007
Hiya Guys
My wolfdale E8400 system is running fine under normal loads.
If I play a game like crysis or Bioshock for more than an hour or so, I get a blue screen.
If I run Orthos, I can only get about half hour to an hour before it blue screens.
I've tried upping the core voltage a few times, but its betting up to 1.38v now, and i dont wanna go higher than this!
So far, the settings are as follows :
In the BIOS, we have a FSB Frequency of 427
Dram fewqueny - 855mhz
Ram timings - 5-5-5-15
CPU Voltage - 1.387v
Ram voltage - 2.15v
in Windows(CPU-Z), core voltage - 1.368v
Core speed - 3843Mhz
Idle temps - 20c
Under load in Orthos - 42c - 45c
Does anyone know why I might be getting crashes under load?
What else can I try apart from the voltage?
I've read that anything near 1.4v is a dnager area...
Cheers for any replies!
DB
Ram voltage - 2.15v
Idle temps - 20c
DB
