I originally just went for 4.4ghz and managed to get that stable @ 1.32 volts and has been stable since then, the other day i decided to have a mess around updated my bios and cleaned out my pc and then proceeded too see what i could get and it seems that my chip is not all that great of an overclocking chip compared to some...
4.4ghz @ 1.31
4.6ghz @ 1.38
4.8ghz @ 1.45
5ghz @ 1.51 (im still under the recommend magic 1.52 intel number
Now the first two are okay overclocks and it should not be a problem running them at all, my question is would the other two be okay for 24/7 use and yes i am fully aware of the fact the chip would degrade faster (maybe knock a good few months of its life) but i am already looking forwards to iver bridge to replace this current setup so i have been wondering why not enjoy the chip as much as possible!!
Temps at 5ghz/1.51 were 37/38 idle 54-56 after 3 mins prime after 30 mins 62-4 ish, I did however crank my fans up ( although when my fans are on low i get @ 4.4ghz 27 idle ish and 44 max load, i really do love my push pull Megahalems with diamond paste)
Just looking for some input before i go and do somthing silly !
4.4ghz @ 1.31
4.6ghz @ 1.38
4.8ghz @ 1.45
