hey all, I been on holiday for a week and i get back today. Try and boot my pc. It turns on no screen or anything just the fans spin about 3 seconds later it will cut out and then turn back on and go in a loop. I seem to think its the PSU gone. Well i took the mobo out and reseated it. and the cpu. I got it to work once, It got stuck at windows loading screen. That was with the same PSU.... I just can't work it out. I have no other PSU to try with it. I have tryed just running with one stick of ram.. Its strange because i was on the pc the morning i left and its not been on since. Its behind a serge protector thingy... The pc is only 3 weeks old........
Anyway i hope you lot can help me out....
Specs are
DS4
2gb consair ram
200gb wd hd
dvd burner
C2D 6300
zalman 9500
antec 900
x1600pro or fx5200 i can try both..
Tagon 500w PSU
all i can think of that it can be a wire thats gotten bent and ripped inside and sometimes contacts when it booted half way once...
Thanks all again Phil
Specs are
DS4
2gb consair ram
200gb wd hd
dvd burner
C2D 6300
zalman 9500
antec 900
Tagon 500w PSU
