Won't boot from USB
12 May 2011
Southampton
I picked up a second hand netbook today. I want to put a fresh XP install on it but it won't boot from USB. I am using Rufus to make a bootable using a disk image of XP I made. I insert the USB stick, it is detected by the bios (the brand and capacity and everything), I set it as first to boot but when it tries to boot it does nothing for 20 seconds and the moves onto the SSD.
I have been hammering the keys incase it is saying "press any key to boot from cd..." but i just can't see it, but nothing happened :(
Any ideas?
Yeah, it'll boot to the SSD that is in there. It just won't boot to USB. When I tell it boot to USB, it shows a black screen with the flashing underscore, and the the underscore moves down a line or two and the SSD kicks in :(
Ensure that rufus is set to write the partition as MBR for csm/bios compatibility.
Hi it won't boot from my Haswell pc. If I tell it to boot from UEFI: General UDisk as a boot override from within the bios, the screen flicks black but then comes back to the Bios. If I tell it to boot to just "General UDisk" I get the same flashing underscore.
Don't install Windows XP.
Adobe Flash and the latest browsers won't support it.
Install Windows 7 or Linux.
If you insist on XP, use WinToFlash to create the media.
In the BIOS, you'll have to enable legacy boot mode.
+1 for Linux, not just for security but because it'll be lighter on resources and last longer.
Bear in mind, you need to use an XP disc image that has SATA drivers. I think that's only SP3, unless they're slipstreamed into a custom image. No SATA drivers = can't install to SATA drives.
I nabbed a USB stick from work and used Win 2 flash instead of rufus or Win32img and it worked! No idea what it did different but nowI can finally do a fresh install.
Thanks for the help
