My system is refusing to boot. Earlier today i accidentally pressed the tab key whilst booting and windows did a memory test which showed no errors, and windows started normally.
Now on booting up the MB stops posting at 52 (test all memory according to the A-Bit manual). Also the keyboard seems inactive... any ideas?
Its never given any trouble since i built it last Nov.
PS i have tried taking the memory out and also tried booting with just 1 stick.. HELP>>>>> Thanks for all advice
PPS... I left the computer on at the post screen whilst typing this and it eventually the MB gave a series of short clicks opened the windows boot manager screen which gives me the choice of starting windows or using the windows memory diagnostic tool. But my keyboard wont work so i cant select or press enter. I have tried a PS2 keyboard with no luck either...
MANAGED TO SORT IT OUT.. RESET CMOS AND FOUND FAULTY USB DEVICE CAUSING PROBLEMS .
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
EVGA GeForce 8800 GT 512MB Superclocked "Crysis Edition" GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (512-P2-E802-AR-CrysisUK)
HD 1.Western Digital Caviar SE16 500GB SATA-II 16MB Cache
HD 2.Western Digital Caviar SE16 500GB SATA-II 16MB Cache
Pioneer DVR-112DBK 18x18 DVD±RW IDE Dual Layer ReWriter
Lian-Li PC-7 PLUS II Aluminium Midi-Tower Case - Black
Corsair HX620W ATX2.2 Modular SLI Compliant PSU(CMPSU-620HXUK)
