i transfered my pc to a new case and now it is not working. all of the components are the same and i have checked the conections many times. It will turn on (green light on the front), the cddrive will work and it makes a whining noise but the cpu fan wont spin and nothing will display on screen. any ideas? what do i need to plug in to begin with? thanks
you can try these out outside your case with the minimum ammount of parts needed (Ex 1Ram Chip ecc..) and then stard adding on components one by one till you have found the fault
