Wood accent case options
6 Nov 2004
Hi guys.
My cousin is building his first PC soon and he likes the look of wood accent cases.
I was just wondering what other viable options are there? That are good quality good airflow etc no real budget as such.
Thank you.
There's a bunch of good choices out there for both M-ATX and ATX builds.
My basket at OcUK:
Total: £667.80 (includes delivery: £27.99)​
Most of these have different colour variants, windowless options etc.
I'm fond of the A3, been tempted to switch my current case over to one. I also built in a 2500X variant earlier this year and it was a solid case, bit pricy for what it is and not to my personal taste but I couldn't really fault it.
£180 (incl. VAT)
£160 (incl. VAT)
£100 (incl. VAT)
£100 (incl. VAT)
£103 (incl. VAT)
£135 (incl. VAT)
£125 (incl. VAT)
The 217 and C8 seem to be his favourites more C8 thank you
Just hold in mind you need to add fans and potentially an RGB hub to the C8.
It is a nice case mind you, reviews well too:
The above is for the "curve" version but the only difference that I can see is the fishbowl window being curved.
I have a Lian Li Dan A3, which is you want a smaller case 'mATX' then I'd recommend it, it's nicely put together, fairly well designed and big enough without being bigger than it needs to be really.
