I currently have a blue Thermaltake Xaser 3 case and quite frankly I am not too keen on the looks anymore because I have the PC in my lounge and it stands out like a giant metallic tank.
I was thinking to make it fit in with the rest of the lounge to convert it into a wooden case.
I have read that some people have done this and I was thinking that before I undertake such a task I should find out a bit more about it and maybe get some ideas on things to consider.
Also if anyone has made a wooden case and therefore can either say its the best case they have had or maybe, don't ever make a wooden case because of these things then I know not to bother.
What sort of things do I need to consider? I understand that I have to build in ventilation and things as normal but do I need more cooling than a normal metal case as wood will increase the heat?
Do I need to think about cutting out vibrations with rubber or some other material as mountings?
Would it be best to just remove the outer metal shell from my current case and use the metal frame inside and just attach the wooden shell to this frame?
Thanks for any help/ideas/opinions on this.
so that kinda put me off. I might make the case out of plywood and then just use solid walnut for the front to make it cheaper.
