Woops, changed my recipe. How long to slow roast a 2.5kg prime rib?
20 Oct 2002
London
Having not really had time to research the best way of cooking my bone-in prime rib, I've just discovered the Serious Eats reverse sear recipe. Which is essentially, low as possible in the oven first (100c ish) then rest, then full whack for 10-15mins when you're ready to serve to get a nice crust.
My question is, how long do you think I'll need to have a 2.5kg two bone rib in the oven at 100c, to get it to the recommended 52c? :)
Thanks! Nothing like a last minute change of plan!
Is it even possible to get something to 130c when the heat source is set to 100c?
Also surely you only want the meat to reach 60c or so.
You can do, low temp plus lokg duration means tender and off the bone.
Do you have a meat thermometer? You can poke it and see.
I'd give it at least 4 hours, realistically could be a little longer.
However, you can very easily allow it to rest for ages if you wrap it well enough. It'll be a fine temperature for serving after you stick it back in for 15 mins at a high temperature to brown the outside.
I have a thermapen so I'm not really worried about killing anyone. Just need some idea of how long it'll take at a lower temperature, shame the Serious Eats article is so vague!
I reckon I'll do 120c for 4hrs ish. But check at 2 and 3hrs..
I'll rest it for 1-1.5hrs so plenty of time to do spuds, gravy etc afterwards.
Well interestingly enough I put it on at 110c but the damn thing was near enough done in 2.5hrs! Are all these temperatures supposed to be non-fan or something?
No issue as we just ate earlier (it also had a very good 2hrs rest) but slightly threw me off : confused:
It was a great bit of beef but I forgot how fatty it was. The girlfriend doesn't really like fatty meat, especially when it's so prominent to see. Damn nice with my red wine gravy and hot horseradish :cool:
It will be done but the duration helps with tenderise it, it breaks down the fat more to give more flavour.
In the end it was perfect. Just took 2.5hrs rather than the 4 I thought! The thermapen was reading 63c on the edges to 53c ish in the middle as I pushed it through slowly (gotta love being able to do that with the thermapen) so it had to come out really.
