I've got a Worcester 38Cdi condensing boiler and need a bit of advice from any other owners as to the recommended setting for the Central Heating and Hot Water Temperature controls on the actual boiler.
My current settings on the boiler are 4 for Central Heating Temperature and 'e' for Hot Water Temperature. My Hot Water Temperature is absolutely fine. However I'm wondering if the Central Heating Temperature needs to be put to 5 or 6 to improve the efficiency and heating times of the system over winter?
The manual doesn't make it clear just to set it to your desired Central Heating Temperature and for effective management of the system to use a thermostat.
All of my radiators have Danfoss TRV's (most set to 3) and the system is run by a Nest V2 thermostat.
Any help or advice would be great.
