Word 2003.
26 Feb 2004
Hampshire, England.
Hey guys,
What’s going on with my Word 2003 :(
Where have all those high numbers come from? I tried the usual trick of restoring the normal.doc template in Application Data but it hasn’t sort the issue out :mad:
Any ideas?
Cheers,
SW.
In page setup, the margins have changed from cm to pt :confused:
Only just noticed that...
How do I restore?
Cheers,
SW.
Right just tried uninstalling/re-installing and the problem has remained? I really don't know how it could have happened :(
It was fine this morning!
I really do need the margins to be back in cm...
Cheers,
SW.
Berserker said:
Tools -> Options, General tab, measurement units (near the bottom). :)
Thanks mate ;)
Don't know how it change by itself though?
Oh well, all sorted now :)
Thanks.
SW.
if you do a search in c:\documents and settings\[username] for normal.dot (make sure you select search hidden files)
normal.dot is the default template
delete it and then run word, word will recreate it again.
