- 9 Dec 2007
This annoys far, far more than it reasonably should. However, it really does make using the program really frustrating for me for some reason, and Im sure there is probably an easy fix.
At the moment the only way I can have the page viewed at 100% zoom and one page above the other, not side by side, is to have the page visible against hte left hand side of the window. Is there any way I can centre the page exactly how it is if you press the 'one page' button, but zoomed in to 100%?
