Word 2007 Scrolly Wheel Zoom
19 Dec 2006
Saudi Arabia né Donegal
Hello all,
Bit of a weird problem, I cannot use the ctrl+scroll wheel to zoom in and out of Word 2007 Documents for some weird reason. It works perfectly in other programs like Excel 2007, just not Word. I've had a nosey through the program settings but can't see anything to disable or enable such a feature.
Anyone know how to get the scroll wheel zoom back working again?
Thanks in advance,
Antar.
Did a quick check and some people are blaming it on graphics drivers. Some are saying changing to windows generic vga driver fixed it for them. might be worth a go to see if that is the case with you. Does seem strange that its only Word that is the issue though.
Could always run the office install file and run a repair or remove and repair on Word?
