Word: Convert smart endnotes into dumb ones
28 Dec 2003
Aberwristwatch
I need to do this in Word 2003 so that when I paste the endnotes into a separate document, the numbers don't all turn into '1'. I've found this macro online but it's failing to run. "Compile error: Invalid Outside Procedure"
Any ideas?
Code:
' Macro created 29/09/99 by Doug Robbins to replace footnotes with textnotes
at end of document
' to replace the footnote reference in the body of the document with a
superscript number.
Dim afnote As Endnote
For Each afnote In ActiveDocument.footnotes
ActiveDocument.Range.InsertAfter vbCr & afnote.Index & vbTab &
afnote.Range
afnote.Reference.InsertBefore "a" & afnote.Index & "a"
Next afnote
For Each afnote In ActiveDocument.Footnotes
afnote.Reference.Delete
Next afnote
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find.Replacement.Font
.Superscript = True
End With
With Selection.Find
.Text = "(a)([0-9]{1,})(a)"
.Replacement.Text = "\2"
.Forward = True
.Wrap = wdFindContinue
.Format = True
.MatchWildcards = True
End With
Selection.Find.Execute Replace:=wdReplaceAll
No, I don't think it was. Have done so now and getting the following:
Run-time error '13':
Type mismatch
On clicking OK, it takes me back into Visual Basic Editor and highlights the first line in yellow
"For Each afnote In ActiveDocument.Footnotes"
yeah, the variable at the top afnote is defined as an Endnote which the highlighted line is trying to jam a Footnote into.
If you have foot notes, change the variable to footnote. Other wise change the lines
to
ActiveDocument.Endnotes
Having a think about what you actually want it to do I've rewritten it like this for you.
This will pick up any endnotes and move them into the body of the document preserving their formatting other than the smart quotes.
Code:
Sub test()
' test Macro
'Application.ScreenUpdating = False
howitwas = Options.AutoFormatAsYouTypeReplaceQuotes
Options.AutoFormatAsYouTypeReplaceQuotes = False
For Each afnote In ActiveDocument.Endnotes
    afnote.Range.FormattedText.Copy
    Set rng = ActiveDocument.Content
    rng.Collapse wdCollapseEnd
    rng.PasteAndFormat (wdFormatOriginalFormatting)
Next afnote
Next afnote
With Selection.Find
    .Replacement.Font.Superscript = True
    .Forward = True
    .Format = True
    .Format = False
    .Text = "[“”]"
    .Replacement.Text = Chr(34)
    .Text = "[‘’]"
    .Replacement.Text = Chr(39)
End With
Options.AutoFormatAsYouTypeReplaceQuotes = howitwas
'Application.ScreenUpdating = True
End Sub
Many thanks for that Simon. Much appreciated. It's failing on the 18th line:
'rng.PasteAndFormat (wdFormatOriginalFormatting)'
Run-time error '4198': Command failed
I've tried it on a document with only two endnotes and it worked fine. The original document has 747
it's a hack but you could try a doevents loop in there. It will of course make the thing run really slowly.
So add this sub below the end sub of your main macro and then on line 19 of the original macro put
wait (1)
Code:
Sub Wait(n As Long)
    Dim t As Date
    t = Now
    Do
        DoEvents
    Loop Until Now >= DateAdd("s", n, t)
End Sub
