Word document encoding
29 Jul 2004
Esher
Hey,
My friend has sent me her uni work which has gone mental. The essay she was writing has been replaced by squares and other random gibberish.
I thought it was the encoding but when i try and change it nothing happens.
Is the file corrupt or can it be solved?
Thanks
Deep
Perhaps an unknown font or language? That results in a bunch of squares.
What format is the file? .doc or .docx?
.doc
I tried converting it to another language then back to english but nothing. I thought that was the problem
You should search her machine and see if theres any temp copies of the document. Sometimes they are left behind if the main document is corrupt.
100% its a .doc
I can't search her machine, she is at brighton uni.
She is taking her laptop to the uni technicians so hopefully all will be well
