Word Document Recovery
they should be saved by default in the roaming profile if using vista usually something like
C:\Users\'insert user name here'\AppData\Roaming\Microsoft\Word\
if using 2007 you can specify where you want document recovery files to be saved in options
xp still has an appdata or simular in the users directory should be in there somewhere
c:\docs and settings\'insert username'\ application data
